Tu veut le workshop ?
http://en.cadillac-club.net/manual_download.php?id=56
Il faut s'inscrire mais ça vaut le coup .
J'ai déjà vu que tu me l'as envoyer par mail.maverick80 a écrit :La mise a jour de quoi ?
Il faut s'inscrire mais ça vaut le coup .![]()
Engine Controls - MIL ON DTC P1101/P0068/P0171/P0174
TECHNICAL
Bulletin No.: 09-06-04032A
Date: August 06, 2009
Subject: Check Engine Light On, DTC P1101, P0068, P0171, P0174 (Reprogram ECM)
Models: 2004-2006 Cadillac SRX, XLR2005-2006 Cadillac STS
Equipped with Engine RPO
Please Refer to GMVIS
Supercede:
This bulletin is being revised to change the labor time information. Please discard Corporate Bulletin Number 09-06-04-032 (06 - Engine/PropulsionSystem)
Condition
Some customers may comment on an illuminated check engine light shortly after a cold start with no engine performance concerns. Upon inspection, DTC P1101 (Intake Air Flow System Performance) may be set.
In some instances, DTCs P0068 (Throttle Body Airflow Performance), P0171 (FuelTrim System Lean Bank 1) and/or P0174 (Fuel Trim System Lean Bank 2) may eventually set as a result of the DTC P1101.
Correction
Verify the condition. If the diagnostics in SI for the conditions described above do not isolate a fault, reprogram the ECM with the revised calibration that has been developed to address this condition. Verify that the multiple diagnostic interface (MDI) that is being used is configured to the PC that will be used.
Opus j'avais oublie, y a tellement de nouveaux SRX, l'omAlucard a écrit : J'ai déjà vu que tu me l'as envoyer par mail.
